Automatic login click Single Sign-On
rtudon
Hi Guys! I was working deploying SSO-passwordless for my Global Protect VPN, using SAML.
But I don't like that Duo shows the Prompt to click "Log in" to successfully send the Push notification on the mobile app,
It's there any way to do this more silence? Or without the prompt? That directly send me the push notification?
Kind regards.
DuoKristina
No, the action to click login is the start of the SSO authentication flow and can't be skipped today.
You can submit a feature request for your desired behavior. Please reach out to your Duo Care team or account team if you have one, or to Duo Support if you don't.
Duo, not DUO.
