06-03-2012 04:21 PM
Does Cisco offer a Small Business 5.8 GHZ muli-band N wireless router? I was looking at putting a client on the RV180W, but it looks like it's only a 2.4GHZ single-band N router. My client was wanting a 5.8 GHZ multi-band N router for his small business.
Thanks!
Solved! Go to Solution.
06-03-2012 07:59 PM
06-03-2012 05:29 PM
5.8 Ghz????
I don't think that's possible. That's outside the range already. Maybe you meant 5.0 Ghz?
06-03-2012 05:42 PM
You're correct. 5 GHZ is what I meant. I was thinking of the older cordless phones before DECT. :-)
To re-phrase my question...
Does Cisco offer a Small Business 5 GHZ muli-band N wireless router? I was looking at putting a client on the RV180W, but it looks like it's only a 2.4GHZ single-band N router. My client was wanting a 5 GHZ multi-band N router for his small business.
Thanks!
06-03-2012 07:59 PM
06-03-2012 08:45 PM
That is perfect. Exactly what he needs. Thanks a bunch!
06-03-2012 10:14 PM
Thanks for the ratings Nathan.
