A static WAN IP address for an DSL connection RV215W
broow
I have a static IP DSL conneciton that  I need to connect the RV215W router to.  I have no way to assign the IP address when selecting PPPoE.
I have to select PPPoE to enter the login information on the DSL but i have no option to enter the static IP address.  Any way i can make this work?
Glenn Martin
Take a look at the document: WAN Configuration on RV215W
Also, If you would, please Mark this answer Correct and rate the answer, if it helps.
Glenn
