I'm using a RV345 firmware 1.0.03.17 as an Anyconnect SSL VPN server. Setup was very easy and it works great! However, it looks like the entire traffic is using TLSv1.2 when i'm locking at the statistic tab (from windows laptop and Android phone). Is the Anyconnect SSL server on the RV34x serie compatible with DTLS? Being able to use UDP would speed up the tunnel speed....
