C881 - Setting a L2 port to L3
E.Zilio
Hi;
I have to configure a C881 to use in addition to the WAN port (the WAN port will be connected to a hub switch that will go to an MPLS network to an ISP) plus another port as the client's LAN access.
It turns out that with the exception of the WAN port, the others I cannot provide an IP - a warning appears (for example, Fast Ethernet 0):
ROUTER-1 (config-if) #ip add 189.20.198.97 255.255.255.248
% IP addresses may not be configured on L2 links.
How do I make an L2 port work as L3?
Greetings
Emerson Zilio
balaji.bandi
If this switch module then it will be Layer 2 only - you can do below :
interface FastEthernet2    - change the interface you like to configure
switchport access vlan  12    - change the vlan number you required
no shut
interface  vlan  12
no shut
Other option may not be required,
no switchport  -- this makes Layer 2 Layer 3 port - so you can allocate IP address
BB
Thanks a lot!
