Cisco 1921 maximum modules
A ND
Hello everyone
i have a cisco 1921 router and i want to use both Cisco HWIC-2FE and Cisco HWIC-1GE-SFP or combination of
Cisco HWIC-1GE-SFP and Cisco EHWIC-1GE-SFP-CU at the same time on the router.
is that possible or  just can use one of this modules on the router?
thank you.
balaji.bandi
I have not tested, but as per the technical specification :
Two integrated EHWIC slots are available on the Cisco 1921 for flexible configurations for support of two modules: One doublewide HWIC-D or two singlewide EHWIC/HWIC modules are supported.
reference :
https://www.cisco.com/c/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/data_sheet_c78-598389.html
BB
marce1000
 - Presumably it is  possible from :
       https://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/product_data_sheet0900aecd8016be8d.html
      https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/high-speed-wan-interface-cards/data_sheet_c78-660124.html
               Both look at Table 3. which allow one for each.
 M.
A ND
A ND
well noting yet.
no one has ever tried this before?
