03-12-2012 04:30 PM
Hi all,
Just wanting to know if there is a way to disable unused LAN interfaces of these Cisco 527W routers. Looking through the configuration interface it doesnt seem to have an option for this.
Also I am having trouble logging into the router via SSH or Telent . When I put the password in it says "access denied" . But password works for the web interface..
Thanks...
Solved! Go to Solution.
03-26-2012 10:00 AM
03-14-2012 03:50 PM
Any help would be appreciated ... Thanks...
03-25-2012 10:50 PM
Can anyone help please ? Thanks.
03-26-2012 10:00 AM
For my experience, no way at the moment.
Regards.
03-26-2012 03:29 PM
Thanks Daniele.
Any idea about not connecting via SSH or Telnet ?
03-27-2012 04:10 AM
I noticed same thing. In my opinion Telnet or SSH are used only for Cisco support. You can try to contact your Small Business Support and ask for a feature request.
Regards.
