Cisco Anywhere Connect connetion to a Cisco RV340 over Remote Desktop
NGS
Hi, i've experienced some Issue with the SSL VPN.
If i connect to the IP with the Cisco Anywhere Client from my Laptop it does work well. But if i try to connect with the Client installed over a Remote Desktop Machine it returns some error.
Ive heard about such a Issue from other Cisco Enterprise Firewalls and also heard about that there is some option to allow SSL VPN Connections from Remote Desktop, but cant find that on the RV340 or also in the Backup File.
Best Regards
ktonev
What is the error message that you are receiving?
