cisco router 1941 not supporting IP SLA
ahemadt0544
I have cisco 1941 router , where i am not able configure below
ip sla auto discovery ip sla 1 icmp-echo 10.103.157.2 source-ip 10.103.157.1 threshold 2000 timeout 2000
present ios is : System image file is "flash0:c1900-universalk9-mz.SPA.154-3.M1.bin" please advice .
8 Replies 8
Aditya Ganjoo
Hi Ahmad,
Could you please share what error you are getting on this ?
As per the IOS you are running we should not be facing any issues with this.
May I know for which command you are getting the error ?
Aditya
Hi Aditya ,
hw you doing , The problem am facing is below
I am going to replace cisco 881 Router with cisco 1941 Router in my office .
config 881.
ip sla 1
 threshold 2000
 timeout 2000
 frequency 5
ip sla schedule 1 life forever start-time now
ip sla 2
 icmp-echo 10.100.100.50
the above configuration is not supported in my New cisco 1941 router .
Ip sla 1 is not support .
please advice there is any command support the same features or its IOS issue .
Hi Ahmed,
Share the show version of the new 1941 router.
Aditya
Thanks in advance for your support .
Lala._zoor(config)#ip sla 1
% Invalid input detected at '^' marker.
Lala.al_kuwait_zoor(config)#icmp ?
hi
SH VERSION
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.4(3)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sat 25-Oct-14 01:02 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Lala.al_zoor uptime is 1 minute
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1941/K9 (revision 1.0) with 491520K/32768K bytes of memory.
Processor board ID FCZ191760TD
2 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
255488K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*1        CISCO1941/K9          FCZ191760TD
Technology Package License Information for Module:'c1900'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      None                 None           None
data          None                 None           None
NtwkEss       None                 None           None
Hi Ahmed,
I do not see Security license enabled on the 1941 router.
We need to enable it to use this feature.
Hope it answers your query.
Aditya
Hi Ahmed,
May i know has the issue been resolved ?
Aditya
Please rate helpful posts.
HI ,
Can please advice , how to enable security license.
Should we pay to get license.
Hi Ahmed,
For enabling this license I would request you to contact your Accounts team.
Aditya
