06-20-2020 03:55 AM
Hi Cisco,
I have Cisco RV 042 Dual Internet VPN Router ( Small Business RV Series Router ) with latest Firmware Version ( v4.2.3.10 ). I have created few users & Configured Group VPN. Also I have Downloaded Cisco Quick VPN Client ( 1.4.2.1) version . When I try to connect to VPN, I receive an below error.
"The remote gateway is not responding. Do you want to wait"
I have tested this Quick VPN Client in Windows 7 & Windows 8 with Compatibility Settings. Also tried with turning Windows Firewall & Defender on & off. After that as well I am getting the same error.
Request to check the attached document for reference.
Kindly request to provide a solution or Workaround for the same.
06-30-2020 07:01 AM
You may check the following…
Note: Quick VPN is now an End-of-Life product, compatible with Windows 7 operating system (32-bit and 64-bit editions).
