cisco rv042g setup problem
raydan123
i have a 2 internal computers
A: 192.168.1.10
B: 192.168.1.11
isp provide 2 ip, x.x.x.110-111
subnet: 224
gateway: x.x.x.97
router:
WAN 1: x.x.x.110
WAN 2: x.x.x.111
i try to setup following
computer A port 80, 21, 3389, 10000 map to WAN 1
computer B port 80, 3389, 8080 map to WAN 2
i bought a cisco rv042g, but it look like can't do what i want.
i try enable DMZ, then set DMZ host to computer A,
i try port range forward, but no way to set which WAN
i also try one to one NAT, but only have 2 public ip
i world like to know rv042g can do what? if not, i will buy another router
jeffrrod
Level 4
Level 4
Dear Customer,
Thank you for reaching the Small Business Support Community.
All I can think of is to set the "Bandwidth Management" settings to assign a better priority to a particular type of traffic to the desired WAN interface, besides that I see nothing else to try.  Please refer to the article below for details;
http://sbkb.cisco.com/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=589
I hope you find this information helpful and please do not hesitate to reach me back if there is any further assistance I may help you with.
Thank you for your time and patience,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
i already sell the router, the router can't do what i want
