Cisco RV100W
vvoitsykh
I have Cisco RV100W.
With firmware 1.0.0.2 iptv work though wires and wi-fi. With new firmware iptv doesnt work via wi-fi but via wires it is work.
Why it could be?
jeffrrod
Level 4
Level 4
Dear Vitalli,
Thank you for reaching Small Business Support Community.
Are you running latest firmware v.1.2.0.9? If not, I suggest you to upgrade to that version.  I would then suggest you to configure QoS Port Based settings on your  LAN port(s) forwarding the IPTV traffic giving it the highest priority (4).
If that configuration setting does not make a difference I then suggest you to contact the Small Business Support Center for further assistance;
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Please do not hesitate to reach me back if there is anything else I may assist you with in the meantime.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
SamirD
Level 5
Level 5
Did you backup and restore your configuration or rebuild it from scratch after the firmware?  Are any of your wireless settings different on the newer firmware?
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
