Cisco RV160 Router, Assign Static IP for OpenVPN Clients
agorsk
I have recently enabled OpenVPN on my Cisco RV160 router using the following guide:
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5879-openvpn-on-rv160-rv260.html#client
I am using OpenVPN to ssh into remote computers (OpenVPN clients); however, each time a client disconnects and reconnects from OpenVPN it gets assigned a different IP. Is there any way to assign a static IP to each OpenVPN client?
6 Replies 6
balaji.bandi
Not that i am aware that is possiblein this models. like static reservation
Instead this is my thoought, if your environment is DNS based, you can resolve computer name DNS with IP address.
even though IP address changed still you can connect DNS name.
BB
Balaji,
Is this possible in any other router models? If so, which ones?
Can you go into additional detail regarding connecting to computer name DNS? Is this something that can be setup in the router settings?
Adam
Not sure in this model you can create different VPN profiles so that devices get always same IP.  as i know ASA .
Do you have any DNS and DHCP in your envrionment, or you can do some Script end device to register, depends on your environment.
https://askme4tech.com/how-resolve-ip-address-hostname-powershell
BB
Balaji,
Do you have documentation to enable this part?
I am not sure about DNS...all the machines connected to the router have DHCP enabled.
@agorsk
You can't configure static IP addresses to be provided to your VPN clients by the RV160x Open VPN server.
As i have stated this is not possible with the model of the device you using.
only option i can see as mentioined IP to DNS resolution, when the device come online update DNS records using some scripts so you can conencting use device name rather IP address.
Make sense ?
BB
