RV345 temperature monitor
EvanC75
Is there a way to monitor the temperature of the Cisco RV345 router?  I do have it in a climate controlled closet but I am still curious to see how hot it gets since it is fan-less.  I did see an old thread about this being a feature request on the old RV320 series routers.  But as of now, I don't see any such option, at least in the web console.
I was even thinking of mounting a 40mm usb exhaust fan on the side.
Regards.
SNMP port 161 (162 is for trap) is the port, i do not where you mentioning this community here ?
i use other snmp test tool its free always handy
https://www.paessler.com/tools/snmptester
BB
5 Replies 5
Thanks I will try that out.  Does it matter which SNMP version I use?
Regards.
no the version not matter results will be the same v3 is more secured. but v2c still good.
BB
Please forgive my ignorance, but I have never used SNMP before.  I setup SNMPv3 and v2c on the router and set a name, contact, and location.   Then set a trap IP and port then applied.
However, I don't know what to do next and I don't know what to do with that MIB download you linked to.  I tried SNMPWalk from SolarWinds but I just get device not responding.
Regards.
BB
