08-16-2019 06:55 PM - edited 08-17-2019 01:23 AM
I am having issues with IPv6 routing on my ##R345 router
Even though IPv6 is properly configured, the router doesn't forward packets.
Configuration:
If I ping from the router, Internet IPv6 can be accessed via WAN1 as well as all hosts via LAN.
This looks like a bug in the firmware, similar to the 320 version https://community.cisco.com/t5/small-business-routers/rv320-and-ipv6-on-xfinity/td-p/2475214
... maybe I'm missing something, so any help would be appreciated.
08-16-2019 11:49 PM - edited 08-16-2019 11:51 PM
Similar to IP4 bug with VLANs.
When created VLANs show correct routes.
When try access internet from LAN no connection. Need ping router first form LAN client and then connect to interent for few seconds.
If use one VLAN1 and static routes all work ok.
Im yesterday talk about this with cisco engineer.
08-17-2019 01:16 AM - edited 08-17-2019 01:17 AM
Thanks for the reply AIKor,
I have updated my initial post and mentioned that I am not using the standard VLAN1, e.g I'm using VLAN24, untagged - so maybe this is a configuration that makes IPv6 to break.
08-17-2019 06:22 AM
08-19-2019 08:35 AM
I had more time to test today and below you will find the outcome:
1. As seen from previous replies, I've used VLAN 24 as untagged, so @AlKor 's suggestion that the tagged vlan traffic might cause the problem does not make sense.
2. I have removed VLAN 24 and used the default VLAN 1, but the routing problem still occurs for IPv6.
08-19-2019 10:17 AM
