- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-30-2019 04:30 PM
Is there suitable WAN router model that have the capacity to at least do the following
- host 3 100Mbps and 1 Gbps WAN links with at least 1Gb throughput
- SSH
- OSPF
- Netflow
- IPsec over GRE tunneling with aes256 and aes128
On another note we've got two Cisco Nexus N9K-C9372TX , performing the following roles:
- hosting VMware hosts and SAN storage
- vPC between the two N9K-C9372TX and the VMware hosts
- HSRP
- intervlan routing and OSPF
- root bridge using vPC
So probably I can just configure at least 4 ports as router port and use that instead of buying extra devices ? Will this be ok concerning the above roles ? Processor and memory usage not above between 10-30% considering the above roles for the two boxes
Any help with hardware specs and IOS version technology will be really appreciated
Solved! Go to Solution.
- Labels:
Small Business Routers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-30-2019 10:57 PM
In the world of revelution anything possible, any device can be used.
But only concern here most people look at Securty / Demarcation of of LAN vs WAN Edge
if your desing of thinking, yes Nexus work,.but you are fully exposed to WAN ( so that is the not best Practice until this is totaly VPLS and Dark Fibre Lines (only mesh network for your organisation)
in related to
- IPsec over GRE tunneling with aes256 and aes128 <-- nexus have limited functionalites, since they meant to be DC Switches (not for WAN edge routers)
Other hand you WAN Edge routers From Cisco
https://www.cisco.com/c/en_uk/products/routers/branch-routers/index.html#~stickynav=2
Look at 4K Models, comes with base and you can upgrade to 1GB speed when your network ready.(or from day 1)
Internms of IOS - IOS-XE is the good move.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-02-2019 12:34 AM - edited 05-02-2019 12:34 AM
Correct you need to buy additional GE module for your extra port requirement.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-30-2019 10:57 PM
in related to
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-01-2019 02:21 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-01-2019 02:30 PM
So if we have to go for the 4451 model, it says Integrated WAN Ports2 PoE GE / SFP then below its shows 2 GE / SFP. Does this mean that it comes with these integrated GE ports ? So in total 4 intergrated GE's then we just have to buy a module that support 2 more GE to make it total of 6 GE ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
