configuration page not opening on SRP521w and stopped on login.cgi
usmantahir9811
Hi friends I am facing the following problem after resting my Cisco Small Business SRP 521W. The problem is when I submit login request then page reload but nothing appears and the URL bar stops on 192.168.15.1/login.cgi and nothing happens next. I tried both default username: admin / cisco
Password: admin / cisco
But the same thing happens all time.any other username or password I tried it says the incorrect username and password.i also attached the screenshot kindly checkthe attachments.srp521 (01).jpg
Sujoy Paria
This is a very old Router model and end of support presently. Default settings of SRP52x were as follows…
Default Settings
Parameter
Value
Device IP
192.168.15.1
Username
cisco
Password
cisco
Admin Username
admin
Admin Password
admin
DHCP Range
192.168.15.100 to 149
Data VLAN
VLAN 1
Voice VLAN
VLAN 100, published to the Cisco VOIP phones via CDP
What is the status in different browsers (like Chrome, Firefox, IE)?
I hope you are using Windows OS, please disable the windows Firewall & any third party antivirus installed on that PC and then check the status once in different browsers.
