crypto pki authenticate
Joe_Tseng1
Can subject-name contain state value?
I want to generate CSR and subject-name can contain the following information.
Organization Name(O)
Organization Unit(OU)
Country Code(C)
State or Province(S)
Locality(L)
Common Name(CN)
When I enter following command, it's show error
input:
subject-name CN=sbctw.foxconn.com,O=Foxconn Electronics Inc.,OU=TW,C=TW,L=TW,S=TW
error:
"CN=sbctw.foxconn.com,O=Foxconn Electronics Inc.,OU=TW,C=TW,L=TW,S=TW" is not a valid subject name
The subject name must be in X.500 (LDAP) format
ISR4331, Version IOS XE 17.03.04a
check below thread
https://community.cisco.com/t5/application-networking/csm-s-csr-generation/td-p/1098943
Good luck
KB
Joe_Tseng1
I found a document provide relative command.
subject-name CN=xxx.com,O=xxx.,OU=TW,C=TW,L=TW,st=TW
problem solved, thx.
