Double WAN Cisco Router to double the throughput speed
lcharbonneau
Where I live, the internet connection available is 100/30. Is it possible to connect a 2nd modem and thus combine the 2 WANs to obtain 200/60?
Has anyone managed to double the output speed? If so, how?
Best,
5 Replies 5
balaji.bandi
I am nore sure what device they are terminating.
One thing i can tell you for now is  you can not double the speed(by mixing 2 links), rather you can split the load to get better perfornance.
once we are more information on the device model and ios code running we can suggest any better way you can do it.
BB
I am using the Cisco RV325 Double WAN
You can use PBR to load traffic between two WAN.
Each will froward part from your lan.
This give you double throughput.
MHM
Is it something that can be done within the Cisco RV325 router? I am trying to double the router upload so that any device could benefit from (2x30) 60Mbps.
Best
