11-27-2020 06:11 PM
Have a Firepower 1010 that keeps enabling SIP Inspection anytime there is a change made via the webui or rebooted. How do I make the change permanent in FTD?
11-28-2020 12:47 AM
How are you disabling ? sip inspection.
is this FTD managed by FMC, - or FTD.
Either case you need to make changes in Flexconnect is the best approach. we had the same issue i followed and make a document as we deployed. some information pulled from different sites to make it work.
https://www.balajibandi.com/?p=1284
11-29-2020 09:53 AM
FTD, I believe. Configuring by SSH.
11-29-2020 10:45 AM
FTD either manage by FDM or FMC, so make sure you config flex config for long saved.
