Gateway to gateway RV320 and RV340
Hi everyone.
I have problem with one client which has two locations. Both had RV320 until last week and both were connected by IPSec gateway to gateway very stable. We decided to upgrade device in main location and purchased RV340. I updated both devices to last firmware version (RV320: v1.3.2.02 - RV340: 1.0.03.17). After programming tunnel with different configurations it is not possible to establish connection between them using the same configuration: IKE with pre-shared key and IKEv1. I have tried different variations in config but no way.
Exist any updated guide or tutorial to make this configuration??
Thanks in advance.
Thanks to everyone. Finally it seems that problem was caused by bad routing in one of the ISP, company headquarters IP was not reachable from remote site. Once ISP changed IP, immediately tunnel liked.
5 Replies 5
balaji.bandi
aturawat
Glad all working as expected, can we mark as solution.
BB
Hello Alejandro,
Glad to see that tunnel is up and working fine.
May we mark this post as solved.
Atul
