Help with Port Forwarding not Working
jasonhammer30
I am having trouble getting rdp (port 3389) to forward to my server (10.20.30.20).  I have made sure it is not an issue with the servers firewall, its just the cisco.  I highlighted in red to what i thought I need in my config to get this  to work.  I have removed the last 2 octets of the public IP info for security .Here is the configuration below:
TAMSATR1#show run
Building configuration...
Current configuration : 11082 bytes
version 15.2
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname TAMSATR1
boot-start-marker
boot system flash:/c880data-universalk9-mz.152-1.T.bin
boot-end-marker
logging count
logging buffered 16384
enable secret
aaa new-model
aaa authentication login default local
aaa authentication login ipsec-vpn local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization console
aaa authorization exec default local
aaa authorization network groupauthor local
aaa session-id common
memory-size iomem 10
clock timezone CST -6 0
clock summer-time CDT recurring
crypto pki trustpoint TP-self-signed-1879941380
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1879941380
revocation-check none
rsakeypair TP-self-signed-1879941380
crypto pki certificate chain TP-self-signed-1879941380
certificate self-signed 01
  3082024B 308201B4 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31383739 39343133 3830301E 170D3131 30393136 31393035
  32305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 38373939
  34313338 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BD7E 754A0A89 33AFD729 7035E8E1 C29A6806 04A31923 5AE2D53E 9181F76C
  ED17D130 FC9B5767 6FD1F58B 87B3A96D FA74E919 8A87376A FF38A712 BD88DB31
  88042B9C CCA8F3A6 39DC2448 CD749FC7 08805AF6 D3CDFFCB 1FE8B9A5 5466B2A4
  E5DFA69E 636B83E4 3A2C02F9 D806A277 E6379EB8 76186B69 EA94D657 70E25B03
  542D0203 010001A3 73307130 0F060355 1D130101 FF040530 030101FF 301E0603
ip dhcp excluded-address 10.20.30.1 10.20.30.99
ip dhcp excluded-address 10.20.30.201 10.20.30.254
ip dhcp excluded-address 10.20.30.250
ip dhcp pool tamDHCPpool
import all
network 10.20.30.0 255.255.255.0
default-router 10.20.30.1
domain-name domain.com
dns-server 10.20.30.20 8.8.8.8
ip domain name tamgmt.com
ip name-server 10.20.30.20
ip cef
no ipv6 cef
license udi pid CISCO881W-GN-A-K9 sn
crypto vpn anyconnect flash:/webvpn/anyconnect-dart-win-2.5.3054-k9.pkg sequence 1
ip tftp source-interface Vlan1
class-map type inspect match-all CCP_SSLVPN
match access-group name CCP_IP
policy-map type inspect ccp-sslvpn-pol
class type inspect CCP_SSLVPN
  pass
zone security sslvpn-zone
crypto isakmp policy 10
encr aes 256
authentication pre-share
group 2
crypto isakmp policy 20
encr aes 192
group 2
crypto isakmp key password
crypto isakmp client configuration group ipsec-ra
key password
dns 10.20.30.20
domain tamgmt.com
pool sat-ipsec-vpn-pool
netmask 255.255.255.0
crypto ipsec transform-set ipsec-ra esp-aes esp-sha-hmac
crypto ipsec transform-set TSET esp-aes esp-sha-hmac
crypto ipsec profile VTI
set security-association replay window-size 512
set transform-set TSET
crypto dynamic-map dynmap 10
set transform-set ipsec-ra
reverse-route
crypto map clientmap client authentication list ipsec-vpn
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface Loopback0
ip address 10.20.250.1 255.255.255.252
ip nat inside
ip virtual-reassembly in
interface Tunnel0
description To AUS
ip address 192.168.10.1 255.255.255.252
load-interval 30
tunnel source
tunnel mode ipsec ipv4
tunnel destination
tunnel protection ipsec profile VTI
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address 1.2.3.4
ip access-group INTERNET_IN in
ip access-group INTERNET_OUT out
ip nat outside
no ip route-cache cef
ip route-cache policy
ip policy route-map IPSEC-RA-ROUTE-MAP
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered Vlan1
zone-member security sslvpn-zone
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.20.30.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip local pool sat-ipsec-vpn-pool 10.20.30.209 10.20.30.239
ip default-gateway 71.41.20.129
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list ACL-POLICY-NAT interface FastEthernet4 overload
ip nat inside source static tcp 10.20.30.20 3389 interface FastEthernet4 3389
ip nat inside source static 10.20.30.20 (public ip)
ip route 0.0.0.0 0.0.0.0 public ip
ip route 10.20.40.0 255.255.255.0 192.168.10.2 name AUS_LAN
ip access-list extended ACL-POLICY-NAT
deny   ip 10.0.0.0 0.255.255.255 10.20.30.208 0.0.0.15
deny   ip 172.16.0.0 0.15.255.255 10.20.30.208 0.0.0.15
deny   ip 192.168.0.0 0.0.255.255 10.20.30.208 0.0.0.15
permit ip 10.20.30.0 0.0.0.255 any
permit ip 10.20.31.208 0.0.0.15 any
ip access-list extended CCP_IP
remark CCP_ACL Category=128
permit ip any any
ip access-list extended INTERNET_IN
permit icmp any any echo
permit icmp any any echo-reply
permit icmp any any unreachable
permit icmp any any time-exceeded
permit esp host 24.153. host 66.196
permit udp host 24.153 host 71.41.eq isakmp
permit tcp host 70.123. host 71.41 eq 22
permit tcp host 72.177. host 71.41 eq 22
permit tcp host 70.123. host 71.41. eq 22
permit tcp any host 71..134 eq 443
permit tcp host 70.123. host 71.41 eq 443
permit tcp host 72.177. host 71.41. eq 443
permit udp host 198.82. host 71.41 eq ntp
permit udp any host 71.41. eq isakmp
permit udp any host 71.41eq non500-isakmp
permit tcp host 192.223. host 71.41. eq 4022
permit tcp host 155.199. host 71.41 eq 4022
permit tcp host 155.199. host 71.41. eq 4022
permit udp host 192.223. host 71.41. eq 4022
permit udp host 155.199. host 71.41. eq 4022
permit tcp any host 10.20.30.20 eq 3389
evaluate INTERNET_REFLECTED
deny   ip any any
ip access-list extended INTERNET_OUT
permit ip any any reflect INTERNET_REFLECTED timeout 300
ip access-list extended IPSEC-RA-ROUTE-MAP
deny   ip 10.20.30.208 0.0.0.15 10.0.0.0 0.255.255.255
deny   ip 10.20.30.224 0.0.0.15 10.0.0.0 0.255.255.255
deny   ip 10.20.30.208 0.0.0.15 172.16.0.0 0.15.255.255
deny   ip 10.20.30.224 0.0.0.15 172.16.0.0 0.15.255.255
deny   ip 10.20.30.208 0.0.0.15 192.168.0.0 0.0.255.255
deny   ip 10.20.30.224 0.0.0.15 192.168.0.0 0.0.255.255
permit ip 10.20.30.208 0.0.0.15 any
deny   ip any any
access-list 23 permit 70.123.
access-list 23 permit 10.20.30.0 0.0.0.255
access-list 24 permit 72.177.
no cdp run
route-map IPSEC-RA-ROUTE-MAP permit 10
match ip address IPSEC-RA-ROUTE-MAP
set ip next-hop 10.20.250.2
banner motd ^C
UNAUTHORIZED ACCESS TO THIS NETWORK DEVICE IS PROHIBITED.
You must have explicit permission to access or configure this device.  All activities performed on this device are logged and violations of this policy may result in disciplinary and/or legal action.
^C
line con 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0
access-class 23 in
privilege level 15
logging synchronous
transport input telnet ssh
line vty 1 4
access-class 23 in
exec-timeout 5 0
privilege level 15
logging synchronous
scheduler max-task-time 5000
ntp server 198.82.1.201
webvpn gateway gateway_1
ip address 71.41. port 443
http-redirect port 80
ssl encryption rc4-md5
ssl trustpoint TP-self-signed-1879941380
inservice
webvpn context TAM-SSL-VPN
title "Titleist Asset Management"
secondary-color white
title-color #CCCC66
text-color black
login-message "RESTRICTED ACCESS"
policy group policy_1
   functions svc-enabled
   svc address-pool "sat-ipsec-vpn-pool"
   svc default-domain "tamgmt.com"
   svc keep-client-installed
   svc split dns "tamgmt.com"
   svc split include 10.0.0.0 255.0.0.0
   svc split include 192.168.0.0 255.255.0.0
   svc split include 172.16.0.0 255.240.0.0
   svc dns-server primary 10.20.30.20
   svc dns-server secondary 66.196.216.10
default-group-policy policy_1
aaa authentication list ciscocp_vpn_xauth_ml_1
gateway gateway_1
ssl authenticate verify all
inservice
end
Jason
NAT config sounds ok.
Try to remove temporary your ACL.
If you reach the server you must check access-list statements.
Regards.
I'll give it a try and let you know,
Daniele,
You are correct.  I removed the ACL and it is now working.
Thank You
