help with rv082
albertldee
i have the RV082 v03 i set it for load balancing i have 2 8gb Adsl modem connected to Wan1 and Wan2
Question how can i assign a certain pc to use the connecton on Wan2, what i would like is to assign a specific pc on the network to wan2
Te-Kai Liu
Level 7
Level 7
Look for the protocol binding settings under System Management>Dual WAN>Edit WAN2.
With a ptotocol binding rule, you can bind all traffic originating from a given IP address to WAN2.
jurodri3
Hello Alber Idee,
Let me share with you some information found on the guide me section about protocol biding configuration step by step.
I hope this information helps you.
http://sbkb.cisco.com/CiscoSB/ukp.aspx?vw=1&docid=69b1889ee61d42bb9a389bf69fb7bf28_Priority_Bandwidth_magement_using_Rv042.xml&pid=4&fcid=&fpid=&slnid=3
If this answer was satisfactory for you, please mark the question as Answered.
Diego Rodriguez
Cisco network engineer
Thank you
