QuickVPN to RV042 frequent disconnects
jallensig
I have an RV042 firmware 4.1.1.01-sp with client vpns established. I have one end user that can connect every time with now issues whatsoever. I have other clients that can connect, but are often dropped. The first day they connected for up to 8 hours with now issue, since then they are lucky to connect and if they do are often dropped. Here is the latest logfile from that machine: (with my ip xxx'd out)
2012/11/19 09:38:29 [STATUS]OS Version: Windows XP
2012/11/19 09:38:29 [STATUS]Windows Firewall is ON
2012/11/19 09:38:29 [STATUS]One network interface detected with IP address 192.168.0.114
2012/11/19 09:38:29 [STATUS]Connecting...
2012/11/19 09:38:29 [DEBUG]Input VPN Server Address = xxx.xxx.xxx.xxx
2012/11/19 09:38:29 [STATUS]Connecting to remote gateway with IP address: xxx.xxx.xxx.xxx
2012/11/19 09:38:31 [STATUS]Remote gateway was reached by https ...
2012/11/19 09:38:31 [WARNING]Remote gateway wasn't reached...
2012/11/19 09:38:31 [WARNING]Failed to connect.
2012/11/19 09:38:32 [STATUS]Remote gateway was reached by https ...
2012/11/19 09:38:32 [WARNING]Remote gateway wasn't reached...
2012/11/19 09:38:32 [WARNING]Failed to connect.
2012/11/19 09:38:32 [WARNING]Failed to connect!
Client machine is windows XP
Is there some more extensive troubleshooting I can provide? Please reply with any suggestions.
Thank you,
Jack
Log from other machine is here:
2012/11/19 11:16:00 [STATUS]OS Version: Windows 7
2012/11/19 11:16:00 [STATUS]Windows Firewall Domain Profile Settings: ON
2012/11/19 11:16:00 [STATUS]Windows Firewall Private Profile Settings: OFF
2012/11/19 11:16:00 [STATUS]One network interface detected with IP address 10.0.2.15
2012/11/19 11:16:00 [STATUS]Connecting...
2012/11/19 11:16:00 [DEBUG]Input VPN Server Address = xxx.xxx.xxx.xxx
2012/11/19 11:16:00 [STATUS]Connecting to remote gateway with IP address: xxx.xxx.xxx.xxx
2012/11/19 11:16:01 [STATUS]Remote gateway was reached by https ...
2012/11/19 11:16:01 [STATUS]Provisioning...
2012/11/19 11:16:10 [STATUS]Success to connect.
2012/11/19 11:16:10 [STATUS]Tunnel is configured. Ping test is about to start.
2012/11/19 11:16:10 [STATUS]Verifying Network...
2012/11/19 11:16:16 [WARNING]Failed to ping remote VPN Router!
2012/11/19 11:16:19 [WARNING]Failed to ping remote VPN Router!
2012/11/19 11:16:22 [WARNING]Failed to ping remote VPN Router!
2012/11/19 11:16:25 [WARNING]Failed to ping remote VPN Router!
2012/11/19 11:16:28 [WARNING]Failed to ping remote VPN Router!
2012/11/19 11:16:31 [WARNING]Ping was blocked, which can be caused by an unexpected disconnect.
2012/11/19 11:16:36 [STATUS]Disconnecting...
2012/11/19 11:16:40 [STATUS]Success to disconnect
jallensig
Here is today's log from client...Can ANYONE reply to this with any help??!?!??!
2012/11/27 10:12:34 [STATUS]OS Version: Windows XP
2012/11/27 10:12:34 [STATUS]Windows Firewall is ON
2012/11/27 10:12:35 [STATUS]One network interface detected with IP address 192.168.0.114
2012/11/27 10:12:35 [STATUS]Connecting...
2012/11/27 10:12:35 [DEBUG]Input VPN Server Address = xxx.xxx.xxx.xxx
2012/11/27 10:12:35 [STATUS]Connecting to remote gateway with IP address: xxx.xxx.xxx.xxx
2012/11/27 10:12:36 [STATUS]Remote gateway was reached by https ...
2012/11/27 10:12:36 [STATUS]Provisioning...
2012/11/27 10:12:43 [STATUS]Success to connect.
2012/11/27 10:12:43 [STATUS]Tunnel is configured. Ping test is about to start.
2012/11/27 10:12:43 [STATUS]Verifying Network...
2012/11/27 10:12:47 [WARNING]Failed to ping remote VPN Router!
2012/11/27 10:12:48 [WARNING]Failed to ping remote VPN Router!
2012/11/27 10:12:49 [WARNING]Failed to ping remote VPN Router!
2012/11/27 10:12:50 [WARNING]Failed to ping remote VPN Router!
2012/11/27 10:12:51 [WARNING]Failed to ping remote VPN Router!
2012/11/27 10:12:52 [WARNING]Ping was blocked, which can be caused by an unexpected disconnect.
2012/11/27 10:12:58 [STATUS]Disconnecting...
2012/11/27 10:13:00 [STATUS]Success to disconnect.
Hi Jack,
Usually the following log entry indicates that the ping reply from the router was blocked:
The last thing the client does is ping the LAN IP of the router. The router replies and something on the PC blocks that reply. Check the PC for third party firewall or antivirus software that would block a ping reply from a different subnet than it's own. Disable/uninstall any such software. Usually when this happens the router shows that the status of the client is "Connected". Is this the case?
- Marty
