03-18-2013 08:38 AM
I just bought the SRP541, and it has the old firmware. I downloaded the new firmware, yet I cannot figure out how to install it. Any pointers? Thanks!
Solved! Go to Solution.
03-18-2013 08:50 AM
Hi Adam,
Make sure that you log in with admin/admin, not cisco/cisco. You will see the upgrade option under the Admin tab.
Cheers
Andy
03-18-2013 08:50 AM
Hi Adam,
Cheers
Andy
03-18-2013 09:01 AM
You, sir, are awesome--thank you very much.
03-18-2013 09:08 AM
My pleasure :-)
As you explore the features, take a look at the following link for further documentation. Admin Guide can be found in Support Documentation links on the righthand side of this page.
Cheers
Andy
