How enable NAT Traversal on RV110W
Hugo Galvan
Hi, I need enable Nat traversal on a router RV110W, I saw that feature on datasheet but I cant find it.
Hugo
6 Replies 6
mpyhala
Level 7
Level 7
Hugo,
Make sure you are on the latest firmware Release 1.2.0.10
http://software.cisco.com/download/release.html?mdfid=283879340&softwareid=282487380&release=1.2.0.10&relind=AVAILABLE&rellifecycle=&reltype=latest
Browse to VPM-> Advanced VPN Setup, NAT Traversal: is at the top of the page.
- Marty
Hi mpyhala!
Thanks for your answer.
The option to upgrade firmware is disabled, I can not update.
Hugo.
Hugo,
You need to be on the same network to upgrade firmware. It cannot be done remotely.
- Marty
I am having the same problem and after upgrading the NAT-T option doesn't appear.
Thank you
After upgrading the firmware the option still doesn't appear.
Hugo.
Hugo, Carlos,
My apologies, I think that I was looking at the RV215W when I posted my original response and assumed that the RV110W VPN settings were the same.
To make a feature request for the RV110W, please open a support case:
www.cisco.com/go/sbsc
- Marty
