How to connect RV220W on wireless network
Sharker51
I just got a cisco RV220W and I try to connect it on my wireless network as client, but it doesn't work.
Do you know if it's possible and how to do that ?
Thanks in advance.
Best Regards
YLR
Tom Watts
Hi Yves, this would be unsupported. You may try to make a WDS peer connection, but most likely this would fail as the router is designed to service as a wireless access point.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
