12-19-2012 02:49 AM
I just installed an RV180 at home. I can not get port forwarding to work - after reading in several forums I realize that I need a firmware 1.0.2.2 that currently is in a beta stage.
Could someone please help me with this?
;o)
/Lennart
12-19-2012 04:19 AM
Hi Lennart, beta firmwares are not openly available. Users which receive the software sign an agreement provided by the Cisco L2 team.
To request a beta firmware, your issue must be documented and verified against an existing bug so it may be determined the beta firmware may fix your problem. If you're experiencing a whole new issue, that also must be documented and then analyzed by Cisco.
The first step to all of this is calling the SBSC
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
I'd recommend you have a few things handy-
Cisco ID
Serial number of router
Current config file
Basic network diagram
Type of internet service
Who is the ISP and what modem
-Tom
Please mark answered for helpful posts
12-19-2012 05:38 AM
OK Tom, thanks for your time.
I think however that I will wait until it is released an re-awaken My Netgear FVS338 that can do what I need apart from throughput.
I would call support, but I have already spent my hours trying to get thru only to be referred to this forum.....
I tried the chat - but no answer
I tried to register via the Web, but there was no way I could get the form to accept my telephone number...
I think from what I read here and in other forums that this is a well confirmed bug, but....
;o)
/L
02-13-2013 01:02 PM
Hi Lennart, thank you for using our forum, my name is Johnnatan I am part of the Small business Support community.I was cheaking your post, I´ve seen your post and I found a document about how to configure sucesfully a port forwarding.
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=2865
I hope you find this answer useful,
*Please mark the question as Answered or rate it so other users can benefit from it"
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
02-14-2013 01:41 AM
Hi Jonathan,
Thanks for the link!
It does howerver not change the situation.
I have found that turning off the DHCP-server of the RV180 solves the problem and my ports are forwarded as they should. I now run the DHCP from my Zentyal server.
Cheers,
/Lennart
02-12-2013 06:41 PM
Hi Lennart,
I currently have an RV180 with firmware 1.0.1.9 and have port forwarding enabled and working. How did you configure your forwarding?
Aaron
02-14-2013 01:52 AM
Hi Aaron,
Thanks for taking an interest!
As you probably have seen from my reply to Jonathan above, I have managed to get it to work by stopping the DHCP server in the RV180.
Do you use the DHCP?
I have first added and configured the services I need that are special and not part of the standard selection. I have then created access rules for them, and last added port forwarding.
First I got very strange behaviors where it sometimes worked and sometimes not depending on the order I made them and when I made changes to them. After turning of DHCP (on the LAN side) it all seems stable!
Cheers,
/Lennart
02-14-2013 05:39 AM
Hi Lennart,
Yes I do use DHCP on my RV180. However for the hosts that I have ports forwarded I put in a static dhcp entry so they get the same IP address everytime they are booted.
The way you described the configuration is how I configured my forwarding as well.
One thing that could also mess up port forwarding on the RV180 is UPnP. I have a Cisco/Linksys IP Webcam that hijacked one of my forwarding rules for a webserver. I had to disable that service on the router. However, that would mess up forwarding no matter where the DHCP service is.
Aaron
