interface input errors
we see input errors on interface Gi0/1 on cisco 1941/K9
Also after resetting counters we see those errors is cumulative once to 2-3 hours
Any suggestions where to start ?
In show logging there is no output from today at all ..
#sh int gi0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is bc16.2222.1111 (bia bc16.2222.1111)
  Description: to LAN-Lehavim
  Internet address is 172.16.55.2/29
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 3/255, rxload 1/255
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 07:15:19
  Queueing strategy: fifo
  Output queue: 0/1024 (size/max)
  30 second input rate 5911000 bits/sec, 2439 packets/sec
  30 second output rate 14787000 bits/sec, 2919 packets/sec
     72815038 packets input, 3854388881 bytes, 0 no buffer
     Received 16169 broadcasts (5648 IP multicasts)
     46 input errors, 0 CRC, 0 frame, 46 overrun, 0 ignored
     0 watchdog, 16164 multicast, 0 pause input
     78723290 packets output, 1917039290 bytes, 0 underruns
     870 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Yesterday it was on 1120 errors .
In show processes cpu his there is no spikes
15 Replies 15
RachelGomez161999
“Input errors” is the sum of all errors in datagrams that were received on the interface being examined. This includes runts, giants, CRC, no buffer, frame, overrun, and ignored counts.
Other input-related errors can also cause the input error count to be increased, and some datagrams may have more than one error; therefore, this sum may not balance with the sum of enumerated input error counts.
This may help you,
Rachel Gomez
