IOS flash successful?
Tim Roelands
I have upgrade our Cisco 892F from version: Version 15.1(2r)T1, RELEASE SOFTWARE (fc1)
to
Version 15.3(3)M, RELEASE SOFTWARE (fc2)
Reason is that the router suddenly rebooted, looks like a bug in the IOS. Crashinfo shows an Unexpected execption to CPU: Vector 1200 0x81413edc.
Well, I uploaded the 15.3 IOS to flash and configured the config file pointing to the new IOS. ((config)# boot system flash: system-image-filename)
Show version now looks like this:
Router#show version
Cisco IOS Software, C890 Software (C890-UNIVERSALK9-M), Version 15.3(3)M, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 22-Jul-13 06:01 by prod_rel_team
ROM: System Bootstrap, Version 15.1(2r)T1, RELEASE SOFTWARE (fc1)
Router uptime is 51 minutes
System returned to ROM by reload at 17:39:44 UTC Tue Jul 29 2014
System image file is "flash:c890-universalk9-mz.153-3.m.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 892F (MPC8300) processor (revision 1.0) with 472064K/52224K bytes of memory.
Processor board ID FCZ1540C3CS
9 FastEthernet interfaces
1 Gigabit Ethernet interface
1 ISDN Basic Rate interface
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
3425968K bytes of USB Flash usbflash0 (Read/Write)
250880K bytes of ATA CompactFlash (Read/Write)
I'm a bit concerned about this line: ROM: System Bootstrap, Version 15.1(2r)T1, RELEASE SOFTWARE (fc1) It looks like the old IOS is still active?
Do I have successful upgrade my 892? Why points the ROM to the old IOS?
Leo Laohoo
If you want to use 15.3(3)M then I'd recommend you use the latter 15.3(3)M3 as this version has more bug fixes than the one you're loaded.
In regards to the ROM, it's a bootstrap and 890F doesn't have any newer bootstrap.  So you're safe.
