03-20-2024 06:52 AM
Hi All,
I have a IR829GW that has a red flashing led on the WLAN.
I need to setup the WLAN for the Wi-Fi to be able to do some basic testing.
Please see below the boot up process and commands used.
IR829 Loader Stage 1 Version 1.8
FPGA version 0x20700 built 2017-6-21
Booted from the upgrade FPGA; SecureBoot did not fallback
Reset reason: CPU reset
BIOS Platform: IR800
BIOS Version: 13
SecureBoot core version: F01047X15.01ada48ab2015-04-03
Microloader version: MA0061R06.0404022015
Booted from the upgrade BIOS
Autoboot is ON, variable: bootstrap:ir800-hv.srp.SPA.2.6.24
Image signature verified
Booting image bootstrap:ir800-hv.srp.SPA.2.6.24
[ 19.109572] kexec: Starting new kernel
RIF heap (initial): 2774816 bytes
RIF<3> Added 2774816 bytes at <0x2015a8e0> to the RIF heap
RIF: Host RAM: 1467000KB required, 1467735KB available
RIF: Host low RAM: 4808KB required, 1467735KB available
RIF: Host RAM unused by memory regions: 735KB total, 735KB low
Processing SRP...
RIF: used 10568/16384 bytes of stack
LynxSecure TRUNK (No Service Packs installed)
Copyright 2004-2016 Lynx Software Technologies, Inc
All rights reserved.
LynxSecure (x86_64) build ENGINEERING created on 01/27/2016 09:35:28
URL: svn://txx.lynx.com/svn/lynxsecure/engr/psubramaniam/tot-20141010/lynxsecure/src
Revision(s): 11396M
Built by: psubramaniam@paricos62.localdomain
Initializing the Internal Timekeeping...
Initializing the System State Manager...
Initializing LynxSecure global data areas.
Number of CPU(s) : 2
Initializing the CPU Support Package.
Initializing LynxSecure page table...
Initializing the Board Support Package.
Initializing Scheduler...
Initializing the VCPU module...
Starting up the other CPUs...
CPUs online: #0 #1
Initializing Device Configuration Virtualization...
Initializing Subject Resources...
Initializing Interrupt Routing...
Initializing Hypercalls...
Heap memory used by LynxSecure: 1746016 (0x1aa460) bytes
Launching Subjects
<3> [0.749702] IOAPIC: IOAPIC 1 initialized, implementation version 32
<3> [0.749702] <E1000> e1000_device_init: initialized E1000 device
<6> PCI: Initializing
<6> PCI: Finished Initializing
Autoboot string flash:ir800-universalk9-mz.SPA.156-3.M3,12;
Booting image: flash:ir800-universalk9-mz.SPA.156-3.M3.... [Multiboot-elf, <0
x110000:0x9e79dcc:0x3aa648>, shtab=0xa3352f8[csvds]:/ir800-universalk9-mz.SPA.1
56-3.M3... , entry=0x1100b0]
[CU:0]
Jumps to: 0x1100b0
Smart Init is enabled
smart init is sizing iomem
TYPE MEMORY_REQ
Onboard devices &
buffer pools 0x03644000
TOTAL: 0x03644000
Rounded IOMEM up to: 55MB.
Using 12 percent iomem. [55MB/448MB]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, ir800 Software (ir800-UNIVERSALK9-M), Version 15.6(3)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Wed 26-Jul-17 01:22 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco IR829GW-LTE-GA-EK9 (revision 2.0) with 365568K/60416K bytes of memory.Installed image archive
Processor board ID FGL214294WX
Last reset from Power-on
FPGA version: 2.7.0
BIOS: version 13 Production
BIOS: date[YYYY/MM/DD] :[2017/3/15]
MCU Bootloader : 28
MCU Application: 31
2 Serial(sync/async) interfaces
7 Gigabit Ethernet interfaces
9 terminal lines
2 Cellular interfaces
1 cisco Embedded AP (s)
DRAM configuration is 72 bits wide with parity disabled.
256K bytes of non-volatile configuration memory.
976562K bytes of ATA System Flash (Read/Write)
250000K bytes of ATA Bootstrap Flash (Read/Write)
transport preferred lat pad telnet rlogin lapb-ta mop udptn v120 ssh
% Invalid input detected at '^' marker.
Press RETURN to get started!
*Jan 2 00:00:00.593: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = ir800 Next reboot level = ipbasek9 and License = ipbasek9
*Jan 2 00:00:00.665: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = ir800 Next reboot level = securityk9 and License = securityk9
*Jan 2 00:00:00.735: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = ir800 Next reboot level = datak9 and License = datak9
*Mar 20 14:24:25.573: CELLULAR: modem in slot 1 powered up
*Mar 20 14:24:25.913: c3600_scp_set_dstaddr2_idb(185)add = 0 name is Wlan-GigabitEthernet0
*Mar 20 14:24:38.703: %ACT2-5-STARTED: ACT2 process started.
*Mar 20 14:24:38.809: %LINEPROTO-5-UPDOWN: Line protocol on Interface wlan-ap0, changed state to up
*Mar 20 14:24:38.809: %LINK-3-UPDOWN: Interface GigabitEthernet5, changed state to up
*Mar 20 14:24:38.809: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Mar 20 14:24:40.257: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar 20 14:24:40.257: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet5, changed state to up
*Mar 20 14:24:40.257: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar 20 14:24:44.653: %IGNITION-5-IGN_ENABLE_CMD: The Ignition Power Management is disabled
*Mar 20 14:24:45.059: %SYS-5-CONFIG_I: Configured from memory by console
*Mar 20 14:24:45.437: %LINK-3-UPDOWN: Interface Async0, changed state to up
*Mar 20 14:24:45.437: %LINK-3-UPDOWN: Interface Async1, changed state to up
*Mar 20 14:24:45.629: %SYS-5-RESTART: System restarted --
*Mar 20 14:24:45.743: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Mar 20 14:24:45.743: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Mar 20 14:24:45.745: %SYS-3-HARIKARI: Process IR800 Test top-level routine exited
*Mar 20 14:24:45.747: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Initialized
*Mar 20 14:24:45.747: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Enabled
*Mar 20 14:24:45.747: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Mar 20 14:24:45.747: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Mar 20 14:24:46.663: %LINK-5-CHANGED: Interface GigabitEthernet0, changed state to administratively down
*Mar 20 14:24:46.681: %LINK-5-CHANGED: Interface GigabitEthernet5, changed state to administratively down
*Mar 20 14:24:47.097: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 20 14:24:47.371: %LINK-3-UPDOWN: Interface Wlan-GigabitEthernet0, changed state to up
*Mar 20 14:24:47.681: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet5, changed state to down
*Mar 20 14:24:48.097: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to down
*Mar 20 14:24:48.165: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2, changed state to down
*Mar 20 14:24:48.235: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3, changed state to down
*Mar 20 14:24:48.303: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4, changed state to down
*Mar 20 14:24:48.371: %LINEPROTO-5-UPDOWN: Line protocol on Interface Wlan-GigabitEthernet0, changed state to up
*Mar 20 14:24:50.043: %IGNITION-5-IGN_TURNED_ON_OFF: The ignition is turned ON
*Mar 20 14:24:56.407: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Mar 20 14:24:56.407: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Mar 20 14:25:16.437: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
*Mar 20 14:26:03.941: %CELLULAR-2-MODEM_UP: Cellular0 modem is now UP.
*Mar 20 14:26:19.761: %IR800_ENV-3-IR800_VDS_HB_MISSED: IOS<->VDS communication channel missed 3 heartbeats
*Mar 20 14:27:04.101: %CELLWAN-2-MODEM_RADIO: Cellular0 Modem radio has been turned on
IR800>
IR800>
IR800>enable
IR800#service-module wlan-ap 0 status
Service Module is Cisco wlan-ap0
Service Module supports session via TTY line 4
Service Module is waiting for registration message
Service Module reset on error is disabled
Service Module heartbeat-reset is enabled
Service Module is in fail open
Service Module status is not available
IR800#service-module wlan-ap 0 session
Trying 192.168.10.20, 2004 ... Open
Connecting to AP console, enter Ctrl-^ followed by x,
then "disconnect" to return to router prompt
ap:
03-20-2024 10:08 AM
WLAN |
2.4GHz 5GHz |
>.... Flashing or Steady Red — The embedded AP803 inside the IR829 has reported a hardware or software problem. |
M.
03-21-2024 01:15 AM
Thanks Marce. I had already realised that the problem is within the AP. However, If its a software issue which I believe it is then I would like to know what to do to fix it.
03-21-2024 02:33 AM
- The only thing you can do is try to use the latest firmware available on the device (if applicable) and check if that can help. If not it can be a hardware problem too , as reported in the documentation. If not convinced you will have to resort to contacting Cisco TAC.
M.
