ISR1000 heat dissipation
aiam_2000
Anyone knows the heat dissipation of ISR-1111-8p in watt or BTU/hr, i could not find it in cisco power tool?
balaji.bandi
check this post may help you :
https://community.cisco.com/t5/routing/asr-1004-heat-dissipation/td-p/1447270
BB
aiam_2000
ISR not ASR
appololgies, let me look my document and get back to you if i find one.
BB
Thanks a lot for checking, hopefully you find it
