ISR4331 - NAT issue %Port 22 is being used by system
theitmedic
I'm trying to add a dynamic and a static NAT on a ISR4331 device. The dynamic works fine but when I enter in the static I get the error "%Port 22 is being used by system". I cleared the ip nat trans*, remove dynamic NAT and added the static first and still get the same error
Any ideas?
interface GigabitEthernet0/0/0
description Outside LAN Interface
ip address 192.168.98.50 255.255.255.0
interface GigabitEthernet0/0/1
description Inside
ip nat inside source route-map NAT-DYNAMIC-RMAP interface GigabitEthernet0/0/0 overload
ip nat inside source static tcp 192.168.1.30 22 192.168.98.50 22 route-map NAT-STATIC-RMAP extendable
route-map NAT-STATIC-RMAP permit 1
match ip address 101
match interface GigabitEthernet0/0/0
route-map NAT-DYNAMIC-RMAP permit 1
I'm running IOS XE version isr4300-universalk9.16.09.03.SPA.bin
GW
Mathias Garcia
The error is fairly self explanatory.
The router is already using port 22 for SSH access to itself and therefore does not allow you to use it for other purposes.
You will have to use another outside port to get this working, perhaps 192.168.98.50 222 as an example.
ip nat inside source static tcp 192.168.1.30 22 192.168.98.50 222 route-map NAT-STATIC-RMAP extendable
This fixed it
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 2.1 cli command "crypto key zeroize rsa" pattern "yes"
action 2.2 wait 5
action 2.3 cli command "yes"
action 5.3 cli command "ip nat inside source static tcp 1.1.1.1 22
80.28.132.236 22"
action 5.5 cli command "crypto key generate rsa general-keys modulus 512"
action 6.0 cli command "end"
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvo68393/?reffering_site=dum
pcr
Interesting.
I guess that as long as you're never going to connect via ssh to the outside interface of the router it's a useful workaround.
I don't like the fact the script will trigger on any link up/down event. I am doing this on an ASR 1002-HX.
Here is the config.
event manager applet NAT authorization bypass
event syslog pattern "%SPA_OIR-6-ONLINECARD:"
action 2.2 wait 5
action 5.3 cli command "ip nat inside source static tcp 172.17.0.66 22 x.x.x.x 22 extendable"
action 5.5 cli command "crypto key generate rsa general-keys modulus 2048 label myrsakey"
Unfortunately  the script did not run at reload.
This is what I found in the  show event manager history events detailed
8 8 Actv abort Thu Sep 3 14:42:31 2020 syslog applet: NAT
msg
*Sep 3 14:42:31.695: %SPA_OIR-6-ONLINECARD: SPA (BUILT-IN-EPA-8x1G) online in subslot 0/0
9 10 Actv abort Thu Sep 3 14:42:41 2020 syslog applet: NAT
msg
*Sep 3 14:42:41.020: %SPA_OIR-6-ONLINECARD: SPA (BUILT-IN-EPA-8x10G) online in subslot 0/1
