MPLS Link
What could be the issue when a link connected to interface GigabitEthernet0/0/2.582 does not come up on the production router but works on a test router.
The config on the interface are okay.
ken-nai-edc-pe01#ping vrf voas001 10.234.253.129 rep 50
Sending 50, 100-byte ICMP Echos to 10.234.253.129, timeout is 2 seconds:
Success rate is 62 percent (31/50), round-trip min/avg/max = 1/1/2 ms
ken-nai-edc-pe01#clear arp-cache vrf voas001 10.234.253.129
ken-nai-edc-pe01#sh arp vrf voas001
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.234.253.128          -   7c0e.ce0d.f603  ARPA   GigabitEthernet0/0/3.582
Internet  10.234.253.129          0   Incomplete      ARPA
ken-nai-edc-pe01#
Sending 5, 100-byte ICMP Echos to 10.234.253.129, timeout is 2 seconds:
The router is also connecting another link which is working fine.
ktonev
Please post your question in the main Routing section. MPLS is not supported on Small Business routers (RV series) so there is less chance for someone to answer you quickly here.
Kris
ktonev
Kris
