11-21-2023 06:17 AM - edited 11-21-2023 09:14 AM
We have 2x Cisco RV320 routers that are at Firmware version V1.3, we are trying to get them on to the latest V1.5 but the update keeps failing. (tried in browser and USB stick directly on router)
Dose anyone have a V1.4 firmware that we can try to step up to before the V1.5? V1.4 is no longer available on the Cisco site.
Thanks!
11-21-2023 06:25 AM
Once of the support have removed the version is removed automatically, if you need you can contact to help you.
11-21-2023 09:16 AM
Was able to install 1.5
Get router in to recovery mode (plug in power when pressing reset) then use tftp to upload the firmware directly.
