No firmware update for Cisco RV130W
Tomasz_Scislo
Each time I try to get information about new firmware I get ""BSD return code: 404. Not found. This error may occur if the file that you are trying to access has been moved or deleted"
Also when I try to download new firmware from my device console I get: "Get firmware information fail"
balaji.bandi
what is the firmware you have, what firmware are you trying to upgrade?
BB
I do not go for any particular firmware version. When I just start any new firmware version check process I get this error.
