I have a RV110W which is am using as a router (not gateway), because it is connected to the DSL modem (not planning to bridge it) through its WAN port. The DSL modem forwards all PPTP traffic to the RV110W.
The only pupose of the RV110W for me is to use it as a VPN router.
Info:
Firmware version: 1.1.0.9
Below are the settings I have:
WAN:
LAN:
N.B. The modem runs a DHCP server, so I am relaying the requets to it
VPN:
N.B. Also tried with 192.168.0.0 and 12.168.2.0 networks; same thing.
Routing Settings:
Routing Table:
NB: 192.168.1.11 and 10 are VPN clients (created automatically).
Firewall:
Users are being able to successfully connect to the VPN; however, there are couple of problems:
1. They are not assigned a gateway; hence, not internet connectivty (i want them to use the remote gateway)
2. They are not able to access the 192.168.0.0 network; hence unable to reach their DNS server and other hosts (run a tracert; they couldn't go beyond the RV110W VPN server IP). For this, i tried to turnoff the firewall on the RV110W, and also tried to create and Access Rule to allow all outboud and inbound traffic between LAN and WAN, but no success.
Where is the missing piece?
Thank you
