PCI Compliance failures
Brian Bergin
Level 4
Level 4
Using a RV340W, a client of ours is now failing PCI compliance scanning as follows:PCI Compliance Fail March 2018-1.jpg
Question is how do we disable all the things the credit card company is claiming are answering on the WAN ports of this firewall?  They force us to whitelist their IPs which, to me, is silly since without them whitelisted no one is going to see any of these services anyway, but they're claiming this is a Cisco problem and needs to be addressed in the hardware setup.
Thanks...
ktonev
Hi Brian, I'd suggest to call the support centre to open a service request so an engineer can advise whether these settings can be changed or you need to raise a feature request.
Kris
