ā03-03-2023 04:31 PM
Hey guys,
I'm trying to setup my home internet on Cisco router. ISP is via PPPoE connection - NBN HFC (cable modem). Router gets stuck on sending PADI packet and it never gets reply from server. I've captured some packets with Wireshark (I've established direct Dial-up connection on my laptop) and there is Cisco router on ISP side (according to MAC address).
Here is my configuration and debug:
interface GigabitEthernet1
no ip address
pppoe enable group 42
pppoe-client dial-pool-number 42
no shutdown
interface Dialer1
mtu 1492
ip address negotiated
encapsulation ppp
dialer pool 42
dialer-group 42
ppp authentication chap callin
ppp chap hostname MY_ISP_NAME
ppp chap password MY_ISP_PASSWORD
dialer-list 42 protocol ip permit
ip route 0.0.0.0 0.0.0.0 Dialer1
I've enabled
debug pppoe packets
debug pppoe errors
debug pppoe events but
*Feb 28 04:44:04.299: Sending PADI: Interface = GigabitEthernet1
*Feb 28 04:44:04.299: pppoe_send_padi:
contiguous pak, size 60
FF FF FF FF FF FF 64 3A EA 02 18 21 88 63 11 09
00 00 00 10 01 01 00 00 01 03 00 08 6A 00 00 01
00 00 1F 17 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00R800#sh pppoe session
1 client session
Uniq ID PPPoE RemMAC Port VT VA State
SID LocMAC VA-st Type
N/A 0 0000.0000.0000 Gi1 Di1 N/A PADISNT
0000.0000.0000
IR800#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
*Feb 28 05:09:31.699: Di1 DDR: ip (s=127.1.3.2, d=8.8.8.8), 100 bytes, outgoing interesting (ip PERMIT)
*Feb 28 05:09:31.699: Di1 DDR: Cannot place call, no dialer string set.
*Feb 28 05:09:33.700: Di1 DDR: ip (s=127.1.3.2, d=8.8.8.8), 100 bytes, outgoing interesting (ip PERMIT)
*Feb 28 05:09:33.700: Di1 DDR: Cannot place call, no dialer string set.
*Feb 28 05:09:35.700: Di1 DDR: ip (s=127.1.3.2, d=8.8.8.8), 100 bytes, outgoing interesting (ip PERMIT)
*Feb 28 05:09:35.700: Di1 DDR: Cannot place call, no dialer string set.
It's sending PADI frame out of correct interface as broadcast message but it never gets reply from svr.
I've tried cloning int G1 MAC address on my TP-Link router and it works. It doesn't look like issue on ISP side. I've verified with ISP that I can use CHAP authentication as well.
Any ideas why the router never gets reply from the server? Do I need to include vpdn config.?
Solved! Go to Solution.
ā03-06-2023 11:44 PM
ā03-07-2023 03:39 AM
OOOO OOO always with this case
ISP say there is no problem and finally we discover that problem for their side.
I will run lab many cases
review these cases to be more ack when you talk with ISP next time
I will share cases today I hope
ā03-04-2023 06:09 AM
Can you post show version (complete output) - there may be some Limitations of the model you have.
ā03-04-2023 12:10 PM
Cisco IOS Software, ir800 Software (ir800-UNIVERSALK9-M), Version 15.7(3)M4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Tue 07-May-19 17:22 by prod_rel_team
ROM: Bootstrap program is IR800
IR800 uptime is 9 minutes
System returned to ROM by Power-on at 03:52:22 UTC Fri Mar 3 2023
System image file is "flash:ir800-universalk9-mz.SPA.157-3.M4b"
Last reload reason: Power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco IR829GW-LTE-GA-ZK9 (revision 2.0) with 365568K/60416K bytes of memory.
Processor board ID FGL2436L87A
Last reset from Power-on
FPGA version: 2.9.0
BIOS: version 24 Production
BIOS: date[YYYY/MM/DD] :[2019/4/17]
MCU Bootloader : 28
MCU Application: 33
2 Serial(sync/async) interfaces
7 Gigabit Ethernet interfaces
9 terminal lines
2 Cellular interfaces
1 cisco Embedded AP (s)
DRAM configuration is 72 bits wide with parity disabled.
256K bytes of non-volatile configuration memory.
976562K bytes of ATA System Flash (Read/Write)
250000K bytes of ATA Bootstrap Flash (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 IR829GW-LTE-GA-ZK9 FGL2436L87A
Suite License Information for Module:'ir800'
Suite Suite Current Type Suite Next reboot
Technology Package License Information for Module:'ir800'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
data datak9 Permanent datak9
Configuration register is 0x102
ā03-08-2023 03:42 AM
hostname IOU2
ip dhcp excluded-address 1.0.0.1
ip dhcp excluded-address 10.0.0.1
ip dhcp pool mhm
network 1.0.0.0 255.255.255.0
ip dhcp pool mhm10
network 10.0.0.0 255.255.255.0
username mhm password 0 mhm
username mhm10 password 0 mhm10
bba-group pppoe mhm
virtual-template 1
bba-group pppoe mhm10
virtual-template 10
interface Ethernet0/0.1
encapsulation dot1Q 1 native
pppoe enable group mhm
interface Ethernet0/0.10
encapsulation dot1Q 10
pppoe enable group mhm10
interface Virtual-Template1
ip address 1.0.0.1 255.255.255.0
peer default ip address dhcp-pool mhm
ppp authentication pap
ppp pap sent-username Ser password 0 mhm
interface Virtual-Template10
ip address 10.0.0.1 255.255.255.0
peer default ip address dhcp-pool mhm10
ppp pap sent-username Ser password 0 mhm10
end
ā03-08-2023 03:44 AM
hostname R1
interface FastEthernet0/0
no ip address
duplex half
pppoe-client dial-pool-number 1
interface Dialer1
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username mhm password 0 mhm
dialer-list 1 protocol ip permit
end
ā03-08-2023 03:47 AM
hostname R2
no ip address
duplex half
pppoe enable group global
pppoe-client dial-pool-number 10
interface Dialer10
encapsulation ppp
dialer pool 10
dialer-group 10
ppp pap sent-username mhm10 password 0 mhm10
dialer-list 10 protocol ip permit
end
ā03-08-2023 03:50 AM - edited ā03-08-2023 05:46 AM
I run lab using two group and one using VLAN1 untag and other times using VLAN10 tag
so Sure the PPPoE server (ISP) must provide you the VLAN tag and group name for your PPPoE.
ā03-09-2023 07:56 PM
Finally I found working configuration:
switchport mode trunk
no ip address
interface Vlan1
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
i
interface Dialer1
mtu 1492
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname XXXX
ppp chap password YYYYY
ppp ipcp dns request accept
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ā03-10-2023 12:35 AM
I an so glad you issue solve finally
And I hope my answer help you in way to find solution.
Good job friend
Have a nice day
MHM
