Problem with RV016...
jorgeortegas
I have two RV016 that works very well with a VPN . Two both routers have two WAN connections (each one). The problem is when WAN1 fails (because the Internet fails) tunnel goes down, and the only way to fix this is if I change the WAN1 cable by the WAN2. I know that RV082 has Tunnel Backup, but RV016 doesn´t. What is the best way to make work two WANs with one Tunnel?
Thanks.
josruiz
Sr. unfortunatly the only way for to reestablish the VPN  connection in this unit is manually, the RV082 is the only router that has the capability of VPN back up.
Note: The RV082 have to be in both lacation, or you need two RV082  with the two internet connections in order to perform this task.
Good evening,
Yes, the RV082 is a nice choice.
Another option might be to use the SA520 (wait for next firmware release) or use the SR520 series, 800 series, or 1811 Cisco routers.  This will require some CLI to implement, and you can use the CCP gui for most.
HTH,
Andrew
