problema con switch cisco sf350 24 ports
jmpatagonia
buen dia tengo un problema con un switch cisco sf350
Cisco SF350 24 Pports
Software Information
Firmware Version (Active Image): 2.5.8.12
Firmware Version (Non-active): 2.5.0.83
El problema es que en mi servidor dhcp a cada minuto el switch esta solicitando ip via dhcp. pero el switch tiene ip fija.
Apr 29 09:54:15 dnsmasq-dhcp[3925085]: 122070 client provides name: Swicht12-Vlan37-Tall-Desa
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 DHCPDISCOVER(eth0.37) 04:5f:b9:a0:44:fb
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 tags: vlan37, eth0.37
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 DHCPOFFER(eth0.37) 10.11.37.118 04:5f:b9:a0:44:fb
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 requested options: 1:netmask, 3:router, 66:tftp-server, 67:bootfile-name,
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 requested options: 54:server-identifier, 125:vendor-id-encap,
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 requested options: 129, 150:tftp-server-address, 131, 132, 6:dns-server,
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 requested options: 15:domain-name, 100:posix-timezone, 43:vendor-encap
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 next server: 10.11.37.15
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 broadcast response
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 sent size: 1 option: 53 message-type 2
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 sent size: 4 option: 54 server-identifier 10.11.37.15
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 sent size: 4 option: 51 lease-time 6h
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 sent size: 4 option: 58 T1 3h
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 sent size: 4 option: 59 T2 5h15m
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 sent size: 4 option: 28 broadcast 10.11.37.255
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 sent size: 23 option: 15 domain-name policia.rionegro.gov.ar
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 sent size: 4 option: 1 netmask 255.255.255.0
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 sent size: 4 option: 6 dns-server 10.11.37.15
Apr 29 09:54:19 dnsmasq-dhcp[3925085]: 122070 sent size: 4 option: 3 router 10.11.37.4
Apr 29 09:54:27 dnsmasq-dhcp[3925085]: 122070 available DHCP range: 10.11.37.100 -- 10.11.37.200
Apr 29 09:54:27 dnsmasq-dhcp[3925085]: 122070 vendor class: CiscoPnP
Saludos.
PD: ya desactive el ciscopnp
balaji.bandi
is the switch acting as DHCP ? of not try below
config t
no ip dhcp server
no ip dhcp relay enable
end
Still issue please  post show run
BB
11 Replies 11
balaji.bandi
config t
no ip dhcp server
end
BB
jmpatagonia
I detect that the dhcp server on message log say
Apr 29 11:04:15 dnsmasq-dhcp[3930030]: 122070 DHCPOFFER(eth0.37) 10.11.37.118 04:5f:b9:a0:44:fb
That --> 04:5f:b9:a0:44:fb is the maccdres of the switch but that 10.11.37.118 is not the ip of the switch !!!!
It is possible that the switch have another IP some where ??
Regards.
jmpatagonia
this message is frequently on the switch log
2147478926 2021-Aug-20 03:33:01 Warning %BOOTP_DHCP_CL-W-DHCPSUBNETEXIST: The device has rejected a duplicated subnet configuration on interface Vlan 1, IP 10.11.37.118, mask 255.255.255.0, DHCP server 10.11.37.15
2147478927 2021-Aug-20 03:31:49 Warning %BOOTP_DHCP_CL-W-DHCPSUBNETEXIST: The device has rejected a duplicated subnet configuration on interface Vlan 1, IP 10.11.37.118, mask 255.255.255.0, DHCP server 10.11.37.15
2147478928 2021-Aug-20 03:30:37 Warning %BOOTP_DHCP_CL-W-DHCPSUBNETEXIST: The device has rejected a duplicated subnet configuration on interface Vlan 1, IP 10.11.37.118, mask 255.255.255.0, DHCP server 10.11.37.15
2147478929 2021-Aug-20 03:29:25 Warning %BOOTP_DHCP_CL-W-DHCPSUBNETEXIST: The device has rejected a duplicated subnet configuration on interface Vlan 1, IP 10.11.37.118, mask 255.255.255.0, DHCP server 10.11.37.15
jmpatagonia
post show run as requested before
BB
jmpatagonia
I believe found the problem
IP Address I/F I/F Status Type Directed Prec Redirect Status
admin/oper Broadcast
0.0.0.0/32 vlan 1 UP/UP DHCP disable No enable Not
receiv
ed
how con I disable DHCP on vlan 1 ?
show run interface vlan 1 - check what config there.
BB
Swichtxx-...#show run interface vlan 1
Empty configuration
I have a lot of this message on console
Swichtxxx...#20-Aug-2021 23:53:13 %BOOTP_DHCP_CL-W-DHCPSUBNETEXIST: The device has rejected a duplicated subnet configuration on interface Vlan 1, IP xx.xx.xx.111, mask 255.255.255.0, DHCP server xx.xx.xx.xx
finally the solution was delete the ipv4 for vlan1, we dont use for the moment.
sure i was in impression you are running everything on VLAN 1, yes cisco suggest not use VLAN 1 default for security reason, yes
interfaface vlan1
shutdown
BB
