Problems with restriction of some domains with router RV320
BobbyMlad78775
Hello, i just tried to restrict some of the domains that can be reach from the PCs that use my router RV320. I did follow all the steps from this link https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb4286-access-rules-configuration-on-rv320-and-rv325-vpn-routers.html
and i've done everything correctly but the domains still can be reach. Any idea why? Any help it will be much appreciated!
P.S. Is it possible the reason to be something in the Access rules?
@BobbyMlad78775
You can't block websites that use HTTPS encryption with the RV320 routers unless you have the web filtering model - RV320-WB-K9-xx. Content/URL  filtering is looking for HTTP traffic only. As a workaround, you can create an access rules that block communication from your LAN to the public IP addresses of the sites you want to block. So you have to issue nslookup <FQDN> in your PC command prompt (attached image) to get all public IP addresses and then create the deny rules.
Hope that helps,
Martin
13 Replies 13
balaji.bandi
Can you post the screenshot , i am more intrested to see first rule.
BB
Hello, Balaji
this is the screenshot.
Thanks for trying to help me
Hello again,
any suggestions for what should i try to fix it?
Thanks in advance!
Sujoy Paria
As per the attached screenshot ‘All Traffic’ allowed from 3 different /24 IP subnet to any destination and from USB interfaces traffic are denied.
What are the domains you are trying to restrict using RV320 router and how you are trying to restrict those domains in RV320 router currently?
Hi Sujoy ,
i didn't explain the situation correctly and also posted wrong link.
This is the link which i followed step by step trying to block some forbidden domains:
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb4231-content-filter-configuration-on-rv320-and-rv325-vpn-router-s.html
So basically i wanna stop all users that use the router to reach few web sides.
I did everything from the link above but the web sides still can be reach.
I am up for any suggestions.
Thanks in advance
@BobbyMlad78775
Hope that helps,
Martin
Thank you very much for your help Martin. So I need to create one access rule for every single site that I want to block right?
Can you also check the screenshot and tell me if the rule it's done corecctly?
Blagodaria ti mnogo!!!
Hello Bobby,
The rule looks fine.
Martin
Hi again Martin,
I’ve done everything as you said but it still doesn’t works.
I am attaching and screenshot of the Access rule table if you see something wrong please let me know.
Also I tried to forbid an HTTP site through the content filter but and that wasn't successful.
If you got another suggestions I am up for them!
Thanks in advance!
Ignore my last message, it works fine now! Thanks a lot Martin, you are great!
You're welcome Bobby!
Martin
Hello it's me again. I just tried to forbid cs-online.club but as you can see on the screenshot that you shared the site got 3 different IP addresses, it's not just one so I created 3 access rules, one for every single IP but the site still can be reach. Any suggestions what should I do? I am attaching screenshots of the access rules that I created.
This is how does it looks the Content Filter. All i want to do is to forbid these 2 websites in Forbidden Domains Table. I wanna make them impossible for reaching from all PCs that use my router. Any help it will be greatly appreciated!
