Reboot RV34xx devices with SNMP?
train_wreck
I haevn't combed through the MIB, which SNMP OID should be used to reboot/reload the RV34x devices?
9 Replies 9
Iliya Gatsev
My name is Iliya Gatsev from Cisco Technical Support Team.
Let me check that.
Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
Is there any update on this matter ?
Romain
nagrajk1969
You will need to use RestAPI/RestConf and/or NETCONF.
Thanks for the answer. Actually that's (also) what I have been trying to do all day, but with no success so far...
That's probably due to the fact that I could not find any relevant documentation about the needed parameters for restconf restart operations...
I found these endoints when I fetch the http//X.X.X.X/restconf/operations:
<ciscosb-sys:system-reboot xmlns:ciscosb-sys="http://cisco.com/ns/ciscosb/system">/restconf/operations/ciscosb-system:system-reboot</ciscosb-sys:system-reboot>
<sys:system-restart xmlns:sys="urn:ietf:params:xml:ns:yang:ietf-system">/restconf/operations/ietf-system:system-restart</sys:system-restart>
<sys:system-shutdown xmlns:sys="urn:ietf:params:xml:ns:yang:ietf-system">/restconf/operations/ietf-system:system-shutdown</sys:system-shutdown>
But when I make a request to either one of them (PUT, PATCH) I get a 405 (method not allowed),
With a POST request all I managed to get so far is a 400 (wrong parameters) with the response bellow:
<errors xmlns="urn:ietf:params:xml:ns:yang:ietf-restconf">
  <error>
    <error-message></error-message>
    <error-path>/ietf-system:system-restart</error-path>
    <error-tag>malformed-message</error-tag>
    <error-type>application</error-type>
  </error>
</errors>
I tried all kinds of body (XML, JSON) and many type of fields (delay, force, which I guessed from googling around ) but none a them made a difference...
Do you have any clues ? Did you manage to restart a RV using restconf ?
Thanks !
Romain
I finally got it working using  YangSuite from cisco's github.
The parameters needed to trigger the reboot was (IN JSON) :
    "system-reboot": [{
        "firmware-state": "active",
        "option": "none"
So in curl format:
curl -L -X POST 'https://X.X.X.X/restconf/operations/ciscosb-system:system-reboot' \
-u "user:password" \
-H 'Content-Type: application/yang-data+json' \
--data-raw '{
    "system-reboot": [{
        "option": "none"
Thanks anyway
Romain
etihaenni
I am currently working on a manner to reboot my RV160 and RV340 routers using a Raspberry pi as a "internet ping watchdog" and discover the trick to reboot these routers with the SNMP command, it is the following:
snmpset -v 2c -c "set community password" "ip address" 1.3.6.1.4.1.9.6.1.110.2.1.1.0 i 2
I found this command using the "Paessler MIB importer v3" in which I import the "CISCOSB-MODEL-MIB.mib" file which I download from here: https://software.cisco.com/download/home/286315556/type/282465797/release/1.0.1
The branch is: CISCOSB-MODEL-MIB --> basic mgt --> mgt system reset
Best regards
Hi there,
My name is Nikola and I'm a Small Business Devices Team member.
When trying to reboot RV34xx please use this MIB version:
https://software.cisco.com/download/home/286288298/type/282465797/release/1.0.1
etihaenni
Dear Nikola,
Thank you very much for your message. Even if this topic is about the RV34x, I refer to the MIB file of the RV160/260 while I didn't find in the MIB files of the RV34x the OID to set a reboot. By chance it's the same OID for RV160/260/340/345
Can you please tell me in which MIB file dedicated to the RV34x you mention above I can find the reboot OID?
As for the RV160/260, there is a lot of MIB files in the downloaded zip, but I didn't find a "CISCOSB-MODEL-MIB.mib" file in the zip file dedicated to the RV34x.
Kind regards
train_wreck
Hey good find, thanks for sharing.
