Reset Cisco 2911 to factory default
Clay Plaga
Level 3
Level 3
I have a Cisco 2911 router with VOIP bundle installed. If I reset the router to factory default, will the flash be affected?
Thank you.
Leo Laohoo
No.
Issue the command "wr erase" and reboot.
Leo Laohoo
No.
I did the reset and it looks like all the files are still in flash.
Thank you.
I have a SM-SRE-700-K9 voice module installed in the 2911. I want to try to configure voice mail on my test network.  What is the gigE interface on the module used for? Can I use this interface to connect to another router?
