Router for CBS350 network
jay.booth
Hey team,
looking for a solution that isn’t crazy expensive to connect internet from an exisiting network that isn’t managed by us (we are an onsite AV supplier in a hotel, hotel IT has given us a port), to multiple VLANs across our network. I know we will need a router, but the Cisco range is not the cheapest. Has anyone had any luck with finding a cost effective router that can spit out vlans and works well with the Cisco range?
edit: we tried a ubiquiti USG as the router and it didn’t want to play nice with the Cisco
balaji.bandi
Can you explain more on this, also explain what you trying to achieve, Hotel give you 1 Ethernet ? after what are you looking to do?
you want to use Hotel connection as WAN and you have a different LAN is this correct?
So you looking your Lan to use WAN connection get internet. then you need NAT here
Try any RV Models  :
https://www.cisco.com/c/en_uk/products/routers/small-business-rv-series-routers/models-comparison.html
BB
We have multiple VLANs running, eg: VLAN 1 is running some video equipment with an IP of 169.254.x.x, VLAN 2 is running control and audio (192.168.0.x), VLAN 3 is running some lighting (192.168.1.x), VLAN 4 is running a storage network (10.0.0.x). So we are wanting to spread the internet access to all these VLANs at once, but would need a router that has VLAN compatibility if I'm correct? So then we could create a Trunk port between the router and the switch
Look at the URL i provided that help you.
BB
Cisco RV series routers are capable to cater that purpose (802.1Q VLAN support available) but End-of-Life (EOL) has been announced already for those routers. Hopefully, newer router models will be available soon under Cisco Small Business / Cisco Business segment.
