Router Linksys RV082, RV016 https problems
elizarraga_c
Problemas con Cisco Linksys RV082 y RV016, en paginas que manejan https, ejemplo www.logmein.com al iniciar sesión me regresa de nuevo a la pagina inicia de inicio de sesión, al investigar encuentro que es una posible suplantación de identidad, por la fucnión que tiene el RV de balancear la carga ya que cambia de un modem a otro modem que este mas libre, esto es uno de los problemas con los que me encontrado y aun no he podido solucionar en un buen tiempo, conocera alguien como arreglar este problemon.
Gracias de antemano.
Problems with Linksys RV082 and RV016 Cisco in pages that handle https, eg when logging www.logmein.com returns me back to the Home page of login, I find it when investigating a possible identity theft, the fucnión VR has the load balance as it changes from a modem to another modem that is more free, this is one of the problems I found and I have not been solved in a while, someone will know how to fix this big problem .
Thanks in advance.
Enrique,
On the RV082:
  1. System Management-> Dual-WAN
  2. Change to Load Balance (Auto Mode) At the bottom of the page you will now see Protocol Binding
  3. Select HTTPS [TCP/443~443] from the dropdown
  4. Select the source IP or IP range: (i.e. 192.168.1.100 to 150) This will bind HTTPS for any LAN device that uses an IP in this range.
  5. Select the Destination IP: Usually leave at 0.0.0.0 to 0.0.0.0 for ALL destinations
  6. Select the Interface to bind the protocol to (WAN1 or WAN2)
  7. Check the Enable box and Add to list. Save Settings at bottom of page.
On the RV016:
  1. System Management-> Multi-WAN
  2. Look for Interface Setting and select Edit for WAN1.
  3. Follow the steps from above.
Please let us know if this helps or if you need further assistance.
7 Replies 7
mpyhala
Level 7
Level 7
Hello Enrique,
Please use Protocol Binding to bind https to only one WAN port. You will find the settings on the same page as the Load Balancing setup. When you connect to a secure site it will no longer show that the connection is coming from two different WAN IPs. If you use RDP you should bind that to one WAN port as well to avoid problems.
Sorry, as I commented to me that, from the router, the page or where??? The truth I know little about this and not what you mean. Show me or tell me where to do this, some document or something.
Thanks in advance.
Enrique,
On the RV082:
On the RV016:
In fact, I had made ​​to move him, he had already done exactly that and apparently show me if there is the matter, I will try it for a few hours and I hope the final solution.
In advance thank you very much, as everything went well see you put your answer as solved.
Enrique,
Thank you for your kind words and you're welcome. I am not able to mark the question as answered since I did not ask it, but you can if you wish.
Mypyhala, creo que no funcionaron las pruebas, ya que las paginas que te comente si cargan bien, pero hay unas que en especifico si presenta la falla, es la de un hosting que al igual utiliza https e inmediatamente muestra la leyenda que la IP ha sido cambiada y no lo permite trabajar, si carga pero al momento que el Router Linksys realiza el cambio de enlace en el balanceador la pagina se sale y muestra la pantalla de que la IP ha sido cambiada.
Que crees que podra ser??
Mypyhala, I do not run the tests, as the pages that you comment if loaded fine, but there are specific that if you have the flaw, is that of a host that uses https as the legend shows immediately that the IP has been changed and not allowed to work, but at the moment if you load the Linksys Router performs the link change in the balance goes out the page and displays the IP that has been changed.
May be you think?
mpyhala, te comento que ya quedo solucionado este problema, tu aportación si ayudo en parte en la la resolución, lo que hice es poner en modo puente mis modem´s y configurar en router linksys en modod PPoE en Setuo>WAN Connection type, y como te mencione agregue tu recomendación y listo se corrigio el problemas con las https.
Muchas gracias por su apoyo, estamos en contacto, seguire haciedo pruebas explotando las demas bondades del equipo.
mpyhala, I commented that it is already solved this problem, your contribution, if helped in part on the resolution, which is made ​​in bridge mode to my linksys router configure modem'sy in modod PPoE in Setu> WAN Connection type, and as mention you add your recommendation and ready fixed problem with https.
Thank you very much for your support, we are in contact, will test haciedo benefits of exploiting the other team.
