ā06-09-2015 04:14 PM
Hello Experts,
I would like to know if there's any way to modify the Subnet Mask dropdown so I change the subnet mask to 255.255.252.0 in the LAN Configuration,
So I can get this network: 192.168.0.1 /22
192.168.0.1
192.168.1.1
192.168.2.1
192.168.3.1
Adrian
Solved! Go to Solution.
ā06-10-2015 01:12 PM
No, the RV042G is limited to only class C subnet. 255.255.255.x
Best Regards,
Mike
Best Regards,
Mike
ā10-10-2022 07:44 PM
Now I need to go from /24 to /29 mask, for the ospf routers especially, but the host remains as usual with ,/24 mask
I appreciate any help
Your sincerely Mahdi
Mahdi
ā10-10-2022 09:44 PM
Mahdi,
Configure the addresses/subnet masks on the routers interfaces as shown below (Note - /29 = 255.255.255.248):
Router-to-Router Links (using /29 Subnet)
Connected Via Switch
Router0(10.5.7.253/29)(G0/0/1.5) <---> (G0/2)Switch3
Router1(10.5.7.252/29)(G0/0/1.5) <---> (G0/1)Switch3
Router13(10.5.7.251/29)(F0/0.5) <---> (F0/2)Switch3
Directly Connected
Router12(10.4.7.252/29)(S0/1/1) <---> (S0/0/0)(10.4.7.253/29)Router13
Router13(10.8.10.253/29)(F0/1) <---> (G0/0/0)(10.8.10.252/29)Router3
Router12(10.6.10.253/29)(S0/1/0) <---> (S0/1/1)(10.6.10.252/29)Router3
Router12(10.11.0.253/29)(F0/0) <---> (F0/1)(10.11.0.252/29)Router2
Remember to mark helpful posts and mark the correct answer as a solution; It helps other users with similar questions.
ā10-11-2022 05:02 PM
Dave
It's possible to ping 8.8.8.8 from pc1 en how should I do?
Mahdi
ā10-20-2022 02:11 PM
hi dave ,
i got a new task where three router ospf with /30 all ip begin with 10.x., between them should communicate where the first three octet are 10.5.6.x in all router connected
and pc 1 : vlan 1 ip address 192.168.1.x/24
pc2 :vlan 2 ip address 192.168.2.x/24
pc3 :192.168.6.x/23 netmasker vlan 3 are connecting to switch 1 which should be connected to router 1 using 802.1 q
from router 2 other side is connected to switch 2 ( pc 4 :vlan 1 ip address 172.16.0.x /23, and pc 7:vlan 2 )
switch 2 should with port-channel, connected to switch 3 which is the last connected to pc5 vlan 2 ip adress 172.16.4.x/23
and more pc6 (/24)to switch 3 connected .
connected to router 3 from the other side there is switch 4 connected with 802.1 q to router 3.
switch 4 is connected to switch 6 and switch 5 using stp
now is the issue from switch 5 to switch 6 which are both are connected using stp .vlan 10 should be blocked here between switch 5 and 6.
ok i have pc 10 /24 subnet conected to switch 5 and pc 9 connected to switch 6
and pc 8 should connected to switch 4
i need your help urgently before tommorow morning
i appreciate any help
you sinceley
I have send you the machine in private mail because I'm really stuck with it
Thanks I advance
mahdi
ā10-20-2022 02:12 PM
I forget to say that I have send you also the paper drawer by the supervisor but as you know miss a lot of things concerning the ip address, in you email
ā10-12-2022 05:52 AM
dave
i have done the changment a bove the ospf works perfectly ,but when i want to ping again from pc 1 to the routers or the server i got request time couldnt ping would you mind help i appreciate your help
you sincely
mahdi
ā10-12-2022 10:07 AM
Mahdi,
I opened the file you sent and was able to successfully ping PC1 to Server0 (10.10.10.253). I was also able to open a web browser on PC1 and view the web page on server0.
Try closing the file, then reopening it in Packet Tracer, and the ping again.
ā10-12-2022 10:17 AM
Thanks I'm not behind the desk but would you mind send me the file I send to you after changing the /29 mask , because when was I the company today was not able to ping would you do some modification and send it to me properly working thanks in advance
Your sincerely
Mahdi
ā10-12-2022 05:53 AM
or shoulld i also change the router ospf 1 or not ? whats your idea
ā10-12-2022 08:00 AM
any help ?
ā10-12-2022 10:41 AM
i have tested thats true it works propely thanks man
ā10-20-2022 10:58 AM
hi dave ,
you sinceley
mahdi
ā10-20-2022 11:31 AM
by the way i forget to write the vlan 10ip : 10.0.0.x/24
in the explanation task
