Router RV042G - Lan Setting/Subnet Mask
dannroovaa
Hello Experts,
I would like to know if there's any way to modify the Subnet Mask dropdown so I change the subnet mask to 255.255.252.0 in the LAN Configuration,
So I can get this network: 192.168.0.1 /22
192.168.0.1
192.168.1.1
192.168.2.1
192.168.3.1
Adrian
16 Replies 16
mahdi benameur
i have a three routers whereas two router able to see each other in ospf mode while the third are not able to see.
all of them are in /30
Mahdi,
The previous problems were attached to multiple already closed/Solved threads and have been fixed. This is a new issue, therefore a new conversation should be started. Since you seem unable to start one yourself, I have done it for you. The new conversation is titled "New task with /30 and/23".
Previous Conversation: Layer 3 Switch cant communicate with Router (PT LAB)
New Conversation: New task with /30 and/23
Remember to mark helpful posts and mark the correct answer as a solution; It helps other users with similar questions.
