Router RV042G - Lan Setting/Subnet Mask
dannroovaa
Hello Experts,
I would like to know if there's any way to modify the Subnet Mask dropdown so I change the subnet mask to 255.255.252.0 in the LAN Configuration,
So I can get this network: 192.168.0.1 /22
192.168.0.1
192.168.1.1
192.168.2.1
192.168.3.1
Adrian
Michael Swenson
No, the RV042G is limited to only class C subnet.  255.255.255.x
Best Regards,
Mike
16 Replies 16
Michael Swenson
Best Regards,
Mike
mahdi benameur
Now I  need to go from /24 to /29 mask, for the ospf routers especially,  but the host remains as usual with ,/24 mask
I appreciate any help
Your sincerely Mahdi
Mahdi
Mahdi,
Configure the addresses/subnet masks on the routers interfaces as shown below (Note - /29 = 255.255.255.248):
Router-to-Router Links (using /29 Subnet)
Connected Via Switch
Router0(10.5.7.253/29)(G0/0/1.5) <---> (G0/2)Switch3
Router1(10.5.7.252/29)(G0/0/1.5) <---> (G0/1)Switch3
Router13(10.5.7.251/29)(F0/0.5) <---> (F0/2)Switch3
Directly Connected
Router12(10.4.7.252/29)(S0/1/1) <---> (S0/0/0)(10.4.7.253/29)Router13
Router13(10.8.10.253/29)(F0/1) <---> (G0/0/0)(10.8.10.252/29)Router3
Router12(10.6.10.253/29)(S0/1/0) <---> (S0/1/1)(10.6.10.252/29)Router3
Router12(10.11.0.253/29)(F0/0) <---> (F0/1)(10.11.0.252/29)Router2
Remember to mark helpful posts and mark the correct answer as a solution; It helps other users with similar questions.
Dave
It's possible to ping 8.8.8.8 from pc1 en how should I do?
Mahdi
hi dave ,
i got a new task where  three router ospf with /30 all ip begin with 10.x., between them should communicate where the first three octet are 10.5.6.x in all router connected
and pc 1 : vlan 1 ip address 192.168.1.x/24
pc2 :vlan 2 ip address 192.168.2.x/24
pc3 :192.168.6.x/23  netmasker vlan 3  are connecting to switch 1 which should be connected to router 1 using 802.1 q
from router 2 other side is connected to switch 2 ( pc 4 :vlan 1 ip address 172.16.0.x /23, and pc 7:vlan 2 )
switch 2 should with port-channel, connected to switch 3 which is the last connected to pc5 vlan 2 ip adress  172.16.4.x/23
and more pc6 (/24)to switch 3 connected  .
connected to router 3 from the other side there is switch 4 connected with 802.1 q to router 3.
switch 4 is connected to switch 6 and switch 5 using stp
now is the issue from switch 5 to switch 6 which are both are connected using stp .vlan 10  should be blocked here between switch 5 and 6.
ok i have pc 10 /24 subnet conected to switch 5 and pc 9 connected to switch 6
and pc 8 should connected to switch 4
i need your help urgently before tommorow morning
i appreciate any help
you sinceley
I have send you the machine in private mail because I'm really stuck with it
Thanks I advance
mahdi
I forget to say that I have send you also the paper drawer by the supervisor  but as you know miss a lot of things concerning the ip address,  in you email
mahdi benameur
dave
i have done the changment a bove the ospf works perfectly ,but when i want to ping again from pc 1 to the routers or the server i got request time couldnt ping would you mind help i appreciate your help
you sincely
mahdi
Mahdi,
I opened the file you sent and was able to successfully ping PC1 to Server0 (10.10.10.253). I was also able to open a web browser on PC1 and view the web page on server0.
Try closing the file, then reopening it in Packet Tracer, and the ping again.
Thanks I'm not behind the desk but would you mind send me the file I send to you after changing the /29 mask , because when was I the company today was not able to ping would you do some modification and send it to me properly working thanks in advance
Your sincerely
Mahdi
mahdi benameur
or shoulld i also change the router ospf 1 or not ? whats your idea
mahdi benameur
any help ?
mahdi benameur
i have tested thats true it works propely thanks man
mahdi benameur
hi dave ,
you sinceley
mahdi
mahdi benameur
by the way i forget to write the vlan 10ip : 10.0.0.x/24
in the explanation task
