Router RV325 DHCP does not work with VLANs, either it assigns everything to VLAN 1 or does not assign IP at all
r.odstrcil
Hello!
I have few VLANs, but Router fails to work properly. Devices are connected via Switch cabled with Port 5 to the Router
a) either it assigns everything to VLAN 1 if I leave ports of VLAN 1 Untagged
b) or does not assign IP at all if I set Port 5 (in VLAN 1) to Tagged. So my devices say connected w/o Internet.
See the setting of my Router for scenario a) attached.
Can anybody help me how to solve it (set it up)?
Thank you!
Thank you balaji for response.
Firmware is 1.5.1.11.
EDIT:
I found the issue in my Switch connected to Trunk on Port 5.
I had there an active DHCP filtering, so it did not accept DHCP for other VLANs (only VLAN 1).
after fixing this, the Router and VLANs work.
Thank you anyway.
balaji.bandi
Since by Default it tagged to VLAN1
check this thread and explain clear : ( also check the firmware you running) ?
https://community.cisco.com/t5/small-business-routers/dhcp-setup-across-multiple-vlans-on-rv325-dhcp-server-only/td-p/2537512
BB
EDIT:
Thank you anyway.
